S80 2004 Transmission problem
Everything on the Volvo S80. Sometimes called an "executive car", the S80 was Volvo's top-of-the-line passenger car. P2 platform.
jun8ior
Year and Model: s80,2004
Post by jun8ior »
Had the transmission flushed, Now the transmission tends to take a second or two to slip into first gear when I first start it up cold. After it warms up and I go from Park to Drive it does fine. Never seems to have this issue going into Reverse tho...should I be concerned? thank you
dcarlson12
Year and Model: 1997 850 T5
Been thanked: 2 times
Post by dcarlson12 »
Maybe it is a stupid question but have you checked the level of the fluid? It wouldn't be the first time that when a tranny is flushed not enough fluid is put in to it by the flushing tech.
vegasjetskier
Year and Model: 2010 Toyota Prius
Been thanked: 6 times
Post by vegasjetskier »
jun8ior wrote:Had the transmission flushed, Now the transmission tends to take a second or two to slip into first gear when I first start it up cold. After it warms up and I go from Park to Drive it does fine. Never seems to have this issue going into Reverse tho...should I be concerned? thank you
Do you have a 6-cylinder engine? If so, did they change the trans filter at the time of the flush? How many miles are on the car?
jun8ior
Post by jun8ior »
transmission oil is good, its a 6 cylinder it has 83000 miles and they did not change the filter thanks for the replys
vegasjetskier
The flush might haved broken loose some gunk which is now clogging up your filter. I'd try changing the filter. Here's how: https://www.matthewsvolvosite.com/forums ... 11&t=20278
jun8ior
Post by jun8ior »
I'll change the filter, and i will let you know if that fix the problem thank you
