760 GLE/1987/Replacing P/S Pump
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
ryanuenchow
Year and Model: 760 GLE 1987
Post by ryanuenchow »
I am replacing my power steering pump with reservoir, and I am just wondering if there is any certain steps or procedures I must take to do this correctly? Or certain tools for this matter. Should I just buy the repair manual for this car?
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
I posted this earlier today for a 240. It is the same for the 760.
The instuctions I have are quite complex so I shall post them for you:
1. Remove pump to bracket retaining bolts.
2. Place a drain pan under the pump.
3. Disconnect the hydraulic connections at the pump.
4. Remove the pump.
Installation is a reverse of the above, minus the drain pan of course. Fill and bleed the system and check for leaks.
You may need a puller to remove the pulley but it isn't specified in my book.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
