Can any S40 96-00 Drivers take a look in their Boot/Trunk
1996 - 2004 S40
1996 - 2004 V40
timwebb
Year and Model: s40 1997
Post by timwebb »
Hi All
I posted a request for info the other day and have not had a response
My wife is going on a long journey and needs to use the radio
Unfortunately I replaced the aerial on her car but dont have the original wiring connector
All i need to know is ................ The aerial has a female connector with six terminals and three wires
One green(ish) one red(ish) one black(ish)
Can someone please look in their boot / trunk and tell me which wire goes where?
If you view it from the back - when connected the terminals are
1 6
2 3 4 5
Can anyone help asap?
Tim
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
Looking at two wiring diagrams for the S40 shows the following wires coming from the plug:
Terminal 3 red/black to fuse box.
Terminal 4 red to radio head unit.
Terminal 6 black to earth (ground).
I hope this helps.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
timwebb
Post by timwebb »
Thank you very, very, much Bill
Now I am thinking that if you used my pin layout it is the centre two pins and the top right for the black?
This seems to make sense as the red and green would be in different halves of the "W" shape and the black would be at the top right
If you could confirm this I would be most grateful and I will post the result after testing
billofdurham
Unfortunately the wiring diagrams show the block in a straight line numbered 1 to 6. However, if the terminal block is shaped and numbered as in your post then I would agree with your reasoning.
Bill.
Previously:
