S60 2002 Front end clunking
S60 Front End Clunking
KJKonstantine
- Year and Model: S60 2002
I've been hearing various clunking and sometimes a "dooing" sound that appear to come from the the front end of my 02 S60. This happens at slow speeds as well as freeway speeds. I've had 2-3 different folks check out the suspension and I am always told that it is OK. I appreciate any help.
Big Bad Jon
- Year and Model: S60, 2002
Swaybar links and tie rod end links are notorious issues on S60's. I would start with the swaybar links if when the vehicle is off the ground there is any vertical movement when you grab hold, the PAIR need replaced. Secondly the tie rod end links go bad often... While you still have the vehicle in the air, you rock your tire up and down and front and back you see much movement they need replaced as a pair. Both are fairly easy repairs, the first is a heck of a lot easier if you have access to an impact wrench. If you do they will break free a BUNCH easier.
- 1408 Views
Last post by Vova585
- 967 Views
Last post by Cees Klumper
- 13 Replies
- 3198 Views
Last post by Clockboy
- 1005 Views
Last post by Eric81583
- 1503 Views
