Replacing radiator on '98 S70 GLT
MikeA
Year and Model: S80 2001
Post by MikeA »
The radiator on my '98 S70 GLT is leaking from the lower corner on the passenger side. Can anyone give me advice on replacing it? It's an automatic so the trany lines connect to the radiator.
confused_al
Year and Model: 1996 TLA wagon
Post by confused_al »
96 850 Platinum Wagon
98 MB ML320
06 V70
95 850 GLT(RIP)
FCPEURO
Year and Model: 2006 XC90 V8
Been thanked: 19 times
Post by FCPEURO »
It is not that hard to replace, just take your time. If you need a radiator, let me know or check our website.
MikeA
Post by MikeA »
Thanks for the info. What is the best way to remove the clips on the transmission lines at the radiator?
FCPEURO
Post by FCPEURO »
When I flushed my radiator, I just stuck a flat head screw driver in the slot to open them up a little bit and then slide the hose off.
Volvo_240_Atari_2600
Year and Model: 89 245 GL
Post by Volvo_240_Atari_2600 »
Mike,
The write up that Confused Al inserted is excellent! I used it when I did my wife's radiator on her 98 v70
Only "p.i.a" I found was having to pull the radiator from underneath... I had no help to hold the radiator when removing and installing but I used a 5 gal bucket as my support while doing and undoing the bolts etc...
I used snap ring pliers to undo and re-install the transmission cooling line clamps. When re-installing the clamps, make sure to use a plastic zip tie to help secure that clamp.
Read this thread...
https://www.matthewsvolvosite.com/forums ... f=1&t=8767
Not sure what mileage you have on your car or the history, but since you are already going to disconnect the colling lines, you may want to consider the transmission fluid flush.
I did it that same day
Good luck
Eric
MikeA
Post by MikeA »
Great, thanks for the advice. It really helps.
MikeA
Post by MikeA »
BTW... how do you do a transmission flush?
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
Check the repair database for detailed instructions on the transmission flush. MadeInJapan posted an excellent writeup with good pictures. I think it is titled Modified Transmission Flush.
MikeA
Post by MikeA »
I replaced the radiator without too much trouble. After I replaced the coolant and fluids that leaked out, I started the car and it wouldn't idle or it idles roughly then dies. When I give it gas, it is fine then dies again when I take my foot of the accelerator. I re-checked all hoses and connections and it looks like everything is right. I tried driving it around the block and it seems to have good power with no hesitation. I think it must be a vacuum hose or something. Any ideas?
