V70 electrical/rear window defrost malfunction Topic is solved
Guest
Post by Guest »
What would be the possible causes that my V70 rear window defrost function, which also for the outside mirrors, keeps switching on/off randomely ? If there is a switch, where is it located ?
Thanks for your help.
Jensen
Post by Jensen »
Check fuse.If good, check relay (no. 208) situated in relay box UNDER main fuse box.
