Greetings,
Would someone please help me? I would like to know the valve adjustment, headbolt torque, and cam timing before I start this project. Also, any advice would be appreciated. Thanks!
Volvo 850 Turbo - Blown Head Gasket
- Year and Model: Many Volvos
- Been thanked: 76 times
I moved you to the appropriate forum so that you can get a quicker response.
There is no valve lash adjustment per se, the valve springs have limitations but they normally aren't a problem. The head bolts are torqued in 3 stages:
Stage 1 - in order - is 15 lb/ft.
Stage 2 - in order - is 37 lb/ft.
Stage 3 - in order - is an additional 130 degrees.
The valve timing at #1 TDC and the tools to hold the cams there are well described in the Haynes manual. Don't even try to do the job without the manual.
One other good resource is available on the site from here:
https://www.matthewsvolvosite.com/downlo ... vo_850.zip
joemay
- Year and Model: 1994 850 trubo wagon
Hey guys i replaced head gasket and head bolts it took about 12 hours . the car seems fine now. i put about a 1000 miles on since repair and it has not used any coolant or oil thanks Joejoemay wrote:Greetings,
renns
- Year and Model: 2005 XC70
- Has thanked: 3 times
- Been thanked: 6 times
Joe,
Congrats! That's quite a job to undertake. Did you do any other work while the head was off? I'm thinking of crankcase ventilation components, timing belt, water pump, and that sort of thing.
1994 850 5-speed wagon, retired at 400,000 km
1998 V70 AWD 5-speed, retired at 358,000 km.
2005 XC70 275,000 km - daily driver
- 1330 Views
Last post by lummert
- 1964 Views
Last post by tryingbe
- 902 Views
Last post by Wvusaxplayer
- 14 Replies
- 3042 Views
Last post by jcdillin
- 2041 Views
Last post by crussell83
