Key wont turn in the ignition past I...
This topic is in the MVS Volvo Repair Database » Key Won't Turn Past Position I
tomczakj
Year and Model: 98 v70
Post by tomczakj »
I have a 98 v70. So i get into my car to go to dinner the other night and my key wont turn in the ignition so the car wont start. It only goes up to I and then stops. The lights wont even come on so I dont think it is even making it to I actually. Can anyone help me figure out what is wrong so I can get it fixed? I could really use it. Thanks
gjz30075
Post by gjz30075 »
Is it possible that your steering wheel is turned? If so, it could be putting pressure on the lock mechanism. Try wiggling the steering wheel in either direction to relieve the pressure, while turning the key.
Greg Z
'97 850 wagon
tomczakj
Post by tomczakj »
No. My wheel is straight. Ive tried turning the wheel at different increments and trying the key but it still doesnt work. Is is possible it could be the ignition switch itself?
mvsuzr
Year and Model: S80 T6 2001
Post by mvsuzr »
Can you try another key?
Did you inspect the key for nicks or bends, or excess wear?
You might also want to move the shifter, this might also bind up the lock.
tomczakj
Post by tomczakj »
Theres nothing wrong with the key. Plus, I'm away at college and I dont have another key. And I have tried shifting it to neutral. That doesnt work either :x
DINO95
Year and Model: 850 1995
Post by DINO95 »
take steering plastic collar off look on left side {sitting in car} two torx screws on round plastic piece on colum in line with key take screws out pull piece off take flat screwdriver put in slot turn should start
bigfinn
Post by bigfinn »
Sorry to say, but it may be time for a new ignition lock cylinder. I replaced mine last year, but the only place to get a new one is at the stealership. Expect to pay $300 for the part, and another $300 for labor. I decided to replace it myself and saved the labor. If this is the case, research how to change it out from previous posts on the ingition lock cylinder.
IPD Sport Springs. Koni Yellows. IPD endlinks. IPD strut bar.
160,000 miles
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
I'm not sure where the '98s were in the sequential changes on the ignition switch. On the 850's they are pure cake and it takes much longer to remove the collar around the steering column than it does to replace the switch. On the later models this thread may be helpful.
https://www.matthewsvolvosite.com/forums ... hp?t=13514
nightc1
Year and Model: 99'V70 Base 140K+Mi
Post by nightc1 »
tomczakj wrote:Theres nothing wrong with the key. Plus, I'm away at college and I dont have another key. And I have tried shifting it to neutral. That doesnt work either :x
So with the key in position 1 you can't press in and hold the shift lock override button and then shift the car to neutral?
That's kind of strange.
Rich@BHX
Post by Rich@BHX »
This must be some kind of a Volvo "past due date" strike action? In my '99 S80 the ignition switch doesn't want to know my key this morning :shock: and wouldn't even turn to I position (only 1/3 of the way from 0 to I)
I left wheels slightly turned yesterday, so the steering is locked, refuses to wiggle at all. Now, where's my screwdriver set...?
