S260 turn signals
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
IDs60
Year and Model: 2004 s60
S260 turn signals
Post by IDs60 »
left turn signal flashed fast,right turn signal stopped flashing.Found turn signal fuse blown,replaced fuse right turn signal works,left turn signal flashes on dash,but does not flash on front side or rear. checked bulbs,socket on left side appears ok Now when i turn off ignition left front, side, rear,light stays on not flashing but just on bright. have to remove fuse to get lights to go out but then i have no turn on right. one of your forums stated to pull fuse 21&22 do you think this will work for me
negroprieto
Year and Model: 2001 V70 T5
Post by negroprieto »
I have the same issue please help :D
