V70 2001 Remove rear speaker to replace brake bulb
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
Fay
Post by Fay »
Hi,
I need to replace one of the brake bulbs on a 2001 V70 turbo. This particular bulb requires removal of the speaker.
The manual says 'Pull out the red tab in the speaker. Then press on the black pin above the extracted red tab and twist out the speaker. '
I have tried everything I can think of and the speaker will not come out. Does anybody have any hints on how to get the speaker out?
I'm not entirely sure I know what the manual is talking about when it mentions the black pin. There is a black rectangle shaped tab just above the red tab. I've tried pushing this toward the rear of the car, pulling it toward me and pushing it down toward the floor of the car. I've tried turning the speaker left and right and nothing works.
Any tips would be appreciated.
Thanks!
Fay
Romort628
Year and Model: 2001
Post by Romort628 »
What book are you getting this from?
http://new.volvocars.com/ownersdocs/200 ... pg114b.jpg
Replacement of rear turn signal and brake light bulbs
Switch off all lights and turn the ignition switch to position 0.
Using a screwdriver, carefully pry off the speaker grille.
Twist the bulb holder counter-clockwise, and withdraw it.
Fit a new bulb.
Fit the bulb holder in place and twist it clockwise.
Refit the speaker and press in the red tab.
Press the speaker grille back into position.
Fay
Post by Fay »
Thanks for the response.
Yes, that was the set of instructions I was talking about. As I mentioned, I'm not sure I know what black pin the instructions refer to. I'm also not sure which way to twist the speaker. So any other clues would be appreciated.
Romort628
Post by Romort628 »
Ok, I did this myself now so I see your confusion.
When it says twist the speaker out it really means pull the top down towards you and lift the speaker out. The black pin they are speaking about is just above the red pin and when they say push it down they should have said pry down with a small screw driver. That how I got mine out.
Fay
Post by Fay »
Thanks Romort628! Your instructions were very helpful and I finally managed to get the speaker out. Knowing I had to pull it toward me helped. I tried to use a screwdriver but that didn't work so I finally grabbed the small opening on either side of the black tab and pulled and it came out. I hope I've attached a picture showing the speaker and the black tab above the extended red tab. There's a yellow arrow pointing to the black tab.
2001 V70 rear speaker.jpg (47.59 KiB) Viewed 4998 times
Then, of course, I discovered that the bulb I was trying to replace was not one where the speaker had to be removed but I don't think I could have seen the bulb unless I did remove the speaker. It was the top brake bulb and I had to remove the access panel on the inside of the cargo area to get to it.
And I would like to talk to whoever designed these small spaces that it's impossible to work in! My hands are scraped from trying to get the various bulbs in and out.
Thanks again!
peterhelfer
Year and Model: xc70 2005
Post by peterhelfer »
I had the same problem, and this solved it - thanks! It's often the case with moldings in cars that you need to pull or twist so hard that if you're pulling the wrong way, you'll break it. Case in point: when it says "Using a screwdriver, carefully pry off the speaker grille.", it would have been helpful to point out that you need to pry at the bottom. If you pry at the top, the retainer tabs break.
g8orade
Year and Model: 2007 XC70
Has thanked: 1 time
Post by g8orade »
Thanks for all of the info here.
The weird key point about removing the speaker is that you push the top tab *away from you*, ie, don't pull down on it, while at the same time needing to pull the speaker in the opposite direction, *toward you*. Once you pull it out and look you can see it, I successfully followed the directions, but I cracked the speaker latch by pushing down on it and it may just break off if I have to do this again. I pried it out by putting the blade of a slot screwdriver between the speaker and the frame and turning it to pry out.
Also, I saw somewhere about before pulling out the bulb, crumple up a towel or newspaper and shove it in down below the bulb in case you drop it pulling it out or putting it back in. I didn't drop mine but if you did, you'd be shopping for another bulb holder and dealing with a rattle most likely forever.
The speaker bracket, not a great pic, but showing the opposite nature of pushing away from you while pulling toward you.
