Speedometer works. Replaced broken gear. Replaced instrument panel and everything worked except odometer. Pulled inst panel to check connections, replaced and odometer worked, but one inst light out. Pulled inst panel again to replace bulb. Now odometer doesn't work.
All connections behind inst panel cleaned and checked, odometer still not working. Any suggestions what to check now?
240 1991 odometer not working
- billofdurham
- Year and Model: 855, 1995
- Been thanked: 5 times
The only thing I can suggest is to strip the thing down again and make sure the gear is still intact and in place. If all is OK in there you may be looking at a replacement unit.
Bill.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Previously:
