Have a 98 v70 non turbo in Florida with 180k
Also have an 89 240 non turbo with 240k
Moving to the Boston area.
Here in Florida there are no inspections.
I hear Massachusetts has vehicle safety and emissions inspections.
Safety I know it will pass, car is in great condition.
Emissions, not so sure.
CEL light has been on for a while now.
Before code was P0305 (misfire cyl 5) about a year ago...
Code cleared and never came back.
August did a a tune up with wrong plugs and code was P0304 (misfire cyl 4)
Replaced NEW bosch platimums for OEM volvo plugs with 4 prongs everything was normal and no misfire codes, but now we have P0455
BillofDurham said this in one thread:
point to a leak in the fuel system which could be something small like the filler cap not being tight enough to a leak in the tank, filler pipe, EVAP canister, EVAP canister shut off valve or any of the lines between these components. I would start with the filler cap, replacing the cap or the seal on the cap.
Will this, if not properly looked at throw an state of Massachusetts emissions inspection to point of failing?
Money is very tight right now and I do not want to spend hauling a florida car all the way up north and be stuck w/o being able to get it legal for the road. Need to know what I should start looking for in order to make repairs myself while I stilll have a garage and warmer weather.
The 240 is fine... smokes a little at start up but this is not all the time.
Is there a vehicle age that a car may become exemt of emissions in Massachusetts?
Thank you.
