940 Wagon, 1995, Sun roof
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
dougr
Year and Model: 1995 940
Post by dougr »
I'm looking for some guidence on getting a jammed sun roof open once the motor goes out or is unable to make the window retract. Specifically, where do you access the mechanism from inside the car and what is involved?
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
I have found this for the '93 & '94 940s but there is no mention of it for the '95. Hopefully it will be the same.
Emergency sun roof operation
If, because of an electrical fault (e.g. a blown fuse), it is not possible to operate the sun roof electrically, then it is manually.
First, using a small screwdriver, remove the two screws that secure the sun roof motor cover to the headliner. Then using a screwdriver, depress the white plastic clutch pin in the center of the motor screw (see illustration) and turn the screw to close or open the roof as desired.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
dougr
Post by dougr »
:D
That was just what I needed. My 95 does not have any screws holding the panel in place. It is just up there by a couple of clips. Other than the pin in screw driver slot is being white rather than black, the operation is as Bill's attachment indicates.
95 240
02 S60
04 V70
billofdurham
Thank you for the update.
Bill.
Previously:
