My turbo gauge is no longer working. I hear the turbo running but the gauge just doesnt move. All my other gauges work just not the turbo. just wondering how to fix it.
Thanks
Fatumn
turbo gauge not working
FlyingVolvo
- Year and Model: 2000 V70XC
- Has thanked: 51 times
- Been thanked: 73 times
Did you check the simple stuff?
Did it get disconnected somewhere? Is there a kink in the line somewhere?
2000 V70XC - 340,000 miles
2023 V60 T8 PE
2023 V60 T8 PE
polskamafia mjl
- Has thanked: 19 times
- Been thanked: 21 times
Have you taken the console out recently? I've heard of people braking the gauge accidentally while they were fixing the odometer or replacing bulbs.
9394volvo850s
- Year and Model: 93 850 5spd 94 850T5
yea mine cam off the gauge too. check there
93 850 5spd 320k (the daily)
94 850 T5 190K (race car)
95 T-5R wagon yellow (summer wag)
90 745 5spd 295k (winter wag)
67 122 2 door 4spd 69k
outdoor7or24
- Year and Model: SOLD 95 855t,93 945t
I have had issues with the vacuum line coming off the vacuum tree. A zip tie helped keeped the elbow snug and it has not pop'd off yet.
You could hear the vacuum sucking air.
Maybe look at that or listen for a line that sounds like it is sucking air.
I did the odometer gear this weekend and the needle for the guage fell off on me. I put it back on,but it kept falling off after it was assembled. I pushed it on pretty good, but now the needle doesn't work. There is a little space between needle and ipc face. Anyone know what I ruined??
- Year and Model: Many Volvos
- Been thanked: 75 times
If you didn't remove the brass nut on the back of the boost gauge before you pried the cluster open then it came apart internally inside of the instrument cluster. Sometimes you can re-center it in its bearings and recover but if it completely broke you can't.
