standard transmission swap
- Year and Model: Many Volvos
- Been thanked: 76 times
The ECU (ECM) is going to be a problem. There were no US specified turbos with a manual transmission hence there are no junk yard ECUs that won't freak out and set a CEL. The ECU from the V70 won't work either.
Some of the tuners may have cracked the code but I don't know specifically which ones. The car will run just fine but when the ECU can't talk to the TCU it will set a CEL.
micah861
- Year and Model: 98 S70, 98 S70 T5M
Wouldnt a TCU from a N/A manual work? Just because im curious, would the car drive (with the manual) without a TCU alltogotherOzark Lee wrote:The ECU (ECM) is going to be a problem. There were no US specified turbos with a manual transmission hence there are no junk yard ECUs that won't freak out and set a CEL. The ECU from the V70 won't work either.
...Le
Red 98 S70 T5M
Black 98 S70 N/A
Black 98 S70 N/A
The manuals don't have a TCU beyond the guy or gal that is behind the wheel with a foot on the clutch pedal and a hand on the shifter. There is no module in the slot.
Some manual TCUs are better than others, it drives me nuts when my wife goes for second in the middle of an intersection from a stop light but I do have the low geared M-56 in the '94. By the time she has dumped the clutch she goes for second, I wrap it up to around 4 grand before I make the move.
The rub is that the US versions of the ECU expect to have a dialogue with the TCU and when the communications stop (as in the automatic transmission and/or the TCU are gone) it freaks out and throws a CEL.
I do believe there are ECU tuners that have dealt with it but I don't know which ones, the last I heard was that IPD had not but perhaps that Rica had, that would make sense since Rica is based in Europe.
http://www.rica.nl/
I have never used them or their parts and I don't endorse them but I have hear that they are quite good. They may also be quite expensive with the ever shrinking dollar.
http://www.rica.nl/
micah861
ok, thanks, i understand now. Do volvo manuals have any tendanceys to wear or break internal parts? The one im looking at is from Toms foriegn auto parts, out of a 98 S70 with 152k miles
Red 98 S70 T5M
Black 98 S70 N/A
Black 98 S70 N/A
Mine is all original with around 227k miles on it, even the clutch is original as far as I can tell. No problems with it whatsoever.
- 1785 Views
Last post by Volvo S80
- 1100 Views
Last post by rspi
- 489 Views
Last post by Bostonfan49
- 1032 Views
Last post by cn90
- 1164 Views
Last post by Salomons Driveway
