while I was driving home the car stalled, I pulled over and it started right back up, but the check engine light was on. It drove fine , I had to make a stop and when I tryed to start the car it took a couple of trys. When I got home and checked there was fresh oil leaking from somewhere above the water pump behind the timing belt.
I have had this car since it was new and have never had to check the check engine light, I've understood that it can be read without a special reader, is this correct or do I need to go to a garage and get it checked
Thanks again for the help and direction you always share
1990 240 wagon check engine light
3basecharlie
- Year and Model: 2002 volvo v-70
- billofdurham
- Year and Model: 855, 1995
- Been thanked: 5 times
You can read the fault codes yourself. Instructions can be found at tests with codes. Scroll down to the fourth post.
Anything you don't understand post for more help.
Bill.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Previously:
- 1869 Views
Last post by durk80
- 6356 Views
- 2783 Views
Last post by Georgeandkira
- 947 Views
Last post by maverill
- 1703 Views
Last post by jimmy57
