New to the forums and I probably should do a search before posting this, but I am crammed for time. so apologies in advance!
My 2001 V70 T5 (165K) won't start after sitting awhile (2 months outside?). It almost starts for 2 seconds but then dies. I had this problem awhile ago and it ended up starting but barely. Has gas, plugs are fine, battery is charging!
My ideas:
Low fuel pressure
Contaminated fuel filter
No codes; any ideas? Thanks so much in advance!
Gabriel
Engine Cranking but not starting; Wants to
- RobTheModd
- Year and Model: 98 S70T5M
- Has thanked: 5 times
- Been thanked: 7 times
gabrielef wrote:\ battery is charging!
Gabriel
Let it charge...
Okay, replaced battery in the end and also the fuel filter; turns out the filter was the wrong P/N due to emission code in VIN. The car just cranks and cranks, no dice on starting. Sputters for half a second but just cranks. Would this be in relation to some O2 codes I got awhile back? Don't have them on me, but had to do with upper limit and I remember that VADIS manual recommended looking at O2 sensor or MAF sensor...Thanks!
- 3787 Views
Last post by FLXC90
- 2625 Views
Last post by MarkCXC90
- 3332 Views
- 51 Replies
- 22552 Views
- 1981 Views
Last post by cantgrumble
