Engine Temp
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 20 times
Post by jblackburn »
So, I've got a question about something I've noticed recently.
Someone else had a similar question over on Brickboard, and I wanted to hear some more opinions before I start thinking anything's wrong.
I'll start off with the picture!
I left home at 7:40 (still haven't bothered to change my clock yet :oops: ), so this is after about 16 minutes of driving.
My car warms up to the point where the heater comes on in about maybe a mile in the mornings and warms up just fine...even when it's really cold, so I'm thinking the thermostat is opening & shutting properly. A large part of my drive to work is tooling along on roads at 35-55 mph; mostly big downhills or flat straight stretches, so the engine never has to work very hard. During the morning (it was 45 this morning) I never really notice my temp gauge get much over 1/4. It runs about the same out on the highway, doing ~70 mph and not working very hard. Around town stop-and-go driving, climbing back up hills on the way home, or even just this summer, it always ran at exactly 3 o' clock on the gauge.
So I guess my question is...does anyone else's car ever run kinda cool? Is this normal, or do I have a bad thermostat or temp sensor and should look into replacing them?
'98 S70 T5
2016 Chevy Cruze Premier
firekiller75
Year and Model: 1997 850, 1998 S70
Post by firekiller75 »
Gotta figure it's not normal. That being said, mine does the exact same thing! 40 degrees this morning, and the entire 35 miles highway of my commute, the temp read low, while the 10 miles of city driving it was half way. I assumed my thermostat was stuck open, just haven't opened up the system yet to see.
'98 S70 n/a with 187k miles, paid $300 for it!
'97 850 n/a wagon, girlfriend's cruiser!
Previous Volvos:
2001 S60 2.4T
1993 240 DL
1986 240 2-door
1984 240 4-speed w/overdrive button
FlyingVolvo
Year and Model: 2000 V70XC
Has thanked: 51 times
Been thanked: 74 times
Post by FlyingVolvo »
I would replace both the thermostat and engine coolant temp sensor (OEM!). That should clear up any problems. While you're at it, might as well flush the coolant and give everything a fresh start.
2000 V70XC - 340,000 miles
2023 V60 T8 PE
confused_al
Year and Model: 1996 TLA wagon
Post by confused_al »
jablackburn wrote:Is this normal, or do I have a bad thermostat or temp sensor and should look into replacing them?
No, its not normal, very likely your t-stat is not working properly (only way to confirm that is to take it out and check). If your ECT is kinda old or still original its always good idea to replace it as well.
96 850 Platinum Wagon
98 MB ML320
06 V70
95 850 GLT(RIP)
jblackburn
Cool, thanks everyone.
Between that and a busted spring seat, it sounds like I may have a valid excuse to avoid the kitchen over Thanksgiving :mrgreen:
'98 S70 T5
Japedo
Post by Japedo »
jablackburn wrote:Cool, thanks everyone.
Thats the spirit!
2003 v70 2.5tawd black/black 120miles
2007 nissan altima 2.5 cvt 107miles
2001 xc70 211 miles " collision"/ parts car
1994 850 turbo 315miles 5 speed "stoped fixing it"
V70Johnson
Post by V70Johnson »
ecbsykes wrote:I would replace both the thermostat and engine coolant temp sensor (OEM!). That should clear up any problems. While you're at it, might as well flush the coolant and give everything a fresh start.
+1!!!
jblackburn
Sure enough, it waited until I was halfway into my 5 hour trip today to decide it was broken. The culprit? Coolant temp sensor, of course. Guess everyone was right!
Stupid car.
'98 S70 T5
jblackburn
Is THIS the coolant temp sensor?
http://www.fcpgroton.com/product-exec/p ... ure+Sensor
http://www.ipdusa.com/version.asp?strPa ... &V_ID=2735
Is it the same for a '98 as a '99-2000? On FCP's site, I see one for 850's and a 99-2000 S70, but not for a 98??? I would think it's the same between years, but just want to double-check before I order it. Anybody know?
'98 S70 T5
