Top end noise AFTER Seafoaming
Locked
renns
Year and Model: 2005 XC70
Has thanked: 3 times
Been thanked: 6 times
Post by renns »
I have a fairly high mileage 850 that is using more oil than I'd like. In an attempt to reduce that somewhat, I thought I'd give the SeaFoam treatment a try. I connected a hose to a spare vacuum port on the tree that's under the plastic cover by the throttle body. I held the throttle open a bit with one hand, and dipped the hose in and out as described elsewhere. After about 1/3 can was used, I stuck the hose in all the way, and let the throttle drop back to idle. I was expecting it to stall at this point, but it ran, albeit rough, and drank the entire can of Seafoam without ever stalling. At this point the engine was shut off, and let to sit for 15 minutes or so.
Upon start-up, the engine ran rough, smoked, and had very loud top-end clatter. The top-end noise subsided a bit, and I went for a spirited drive in the country to let the smoke dissipate. I was hoping the noise would disappear, and it did get a bit better, but was still present. Upon return, the noise was still there, although now sounding like one lifter rather than half a dozen. I had to make a 100 mile round-trip drive last night, so I took the 850, hoping time would loosen that lifter. Unfortunately, it's still there upon return.
Today I changed oil, hoping that might cure it, but the noise remains. I've got another shorter trip, about 60 miles, today, so we'll see if that helps out.
Any thoughts on this? I searched and found one guy on VS reported a similar problem a few months back, but never posted a follow-up.
1994 850 5-speed wagon, retired at 400,000 km
1998 V70 AWD 5-speed, retired at 358,000 km.
2005 XC70 275,000 km - daily driver
mvsuzr
Year and Model: S80 T6 2001
Post by mvsuzr »
Did a quick search on "seafoam" on this site, 496 hits...
May be something to check. Grab a cup of coffee and enjoy...
ahuggard
Post by ahuggard »
I know there have been many posts on Seafoam and one in particular that was quite long that described his dissatisfaction with the stuff. Look for that thread in the search.
I've used Seafoam on most of my high mileage Volvos with no problem. I never put a full can through the intake however. 1/3 of can is about all that is required/recommended.
Alex
99 V70 T5 206k
97 850 NA 183k (totaled)
98 V70 GLT 98k (sold, wish I hadn't)
95 940 turbo wagon 102k (totaled)
renns
Post by renns »
I'm running fresh 10w30 and a Mann filter. After 50 miles today, still no improvement. Please don't reply here - I've added my info to the much larger Seafoam thread here:
https://www.matthewsvolvosite.com/forums ... 07#p104907
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2652 times
Been thanked: 1242 times
Post by matthew1 »
Locked at author's request (and I concur).
Also -> Amazon link
Locked
