940 1993 Electric antenna/ Dash air nozzle
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
rocky334
Year and Model: Volvo 940 1993
Post by rocky334 »
(1) I suspect that the operating cable has broken, can this problem be
fixed simply by installing a new antenna already fitted with a cable or
does the entire assembly have to be replaced? Cost difference is something like $17.00 vs. $250.00
(2) How does one remove the passenger side dash mounted air
inlet nozzle, I pulled directly out with a reasonable amount of
force but it will not budge, since it's made of plastic I'm afraid
that it will break if I use too much force. Are there any screws or
mounting clips that have to be removed or released?
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
1. By operating cable do you mean the toothed plastic strip that raises and lowers the rod? Can you hear the motor turning in the base of the unit?
2.The vents are a tight fit and the best way to get them out is with a weather strip tool. Prise out one side about 1/4" then work on the other side until it is out about the same distance. You should then be able to pull it straight out. If it refuses to come then prise again with the tool.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
