A/C problem
Everything on the Volvo S80. Sometimes called an "executive car", the S80 was Volvo's top-of-the-line passenger car. P2 platform.
fcani
A/C problem
Post by fcani »
The A/C of my S80 99 dosent work properly...
The side of passenger not cooling like the driver side.
18º set for the two sides.
Any one have some ideia wath i can do???
Sorry for bad english. :oops:
Volvo S80 T6 1999
vegasjetskier
Year and Model: 2010 Toyota Prius
Been thanked: 6 times
Post by vegasjetskier »
You might have a bad damper motor on the passenger's side. What happens if you turn on the heat?
fcani
Post by fcani »
if i turn on the heat works fine...
only if i turn cooling the air cames warm on the passenger side...
Volvo S80 T6 1999
jbrown122
Year and Model: 1999 V70, 1995 850
Post by jbrown122 »
My V70 did this before. The heat was on and the passengers side was cool. I turned the temp to cold, then back to hot. And it works fine now.
Turn the heat on low, and put it on cool. Then switch it to warm, can you hear any noise? If not, the damper motor, or damper door whatever might be bad.
fcani
Post by fcani »
Were is the Dump motor of passengers side???
How can i test this??
Volvo S80 T6 1999
