2.5T strength
How to go faster, stop quicker, and turn harder. Chips, exhaust, larger turbos, bigger/slotted/drilled rotors, high performance brake pads, manual boost controllers, performance shocks/struts/springs, airbox mods and more! Also discussion on HID and Xenon lights, aftermarket foglights and other exterior lighting.
dstewart
2.5T strength
Post by dstewart »
Does anyone know much boost the 2.5 engine can safely handle?
Guest
Post by Guest »
which 2.5 engine?
550 @ volvospeed
Post by 550 @ volvospeed »
Really, I mean if you have proper fueling and cooling, you can probably hit pretty high (assuming you deal with fuel cut out at 14 psi(1 bar)). With say an MBC I wouldn't run more than 9-10 psi. The problem with adding more boost like that is fueling. You run the engine lean which is bad. At extended amounts of time that can be very bad. So a little is fine.
If you want more info come over to volvospeed and send a PM to
JHEIII850Turbo
smart guy knows his stuff
-Joe
