MareJanee7
1996 S850 Wagon ABS light on intermittently
MareJanee7
- Year and Model: 1996 S850 Wagon
Is there a danger of my brakes failing completely? Occasionally I feel a buzzing sound in the brake pedal when I begin to apply pressure on the pedal.
MareJanee7
MareJanee7
IVIUSTANG
- Year and Model: 2006 XC70
- Been thanked: 4 times
The buzzing is from the ABS pump priming up, no worry over outright brake failure as a result of ABS system failure. ABS module failure is a very common item on these cars, read the following: https://www.matthewsvolvosite.com/forums ... hp?p=46827
Most people here will agree that a module rebuild is more reliable than a brand new unit.
- Jesse
- Jesse
1998 S70 T5 SE 290,000 KM sideswiped total loss(Sweet ride!)
2007 S60 2.5T loaded 63,000 KM SOLD!
2006 XC70 350,000 KM, 2" BadSwede lift kit, steel skidplate, Hilton Stage 1 tune, big burly tires
2008 S80 V8 245,000 KM SOLD!
2015 V60 T5 Premier+ 98,000KM
MareJanee7
After reading and looking over the attachment about the module rebuild, I'm not sure I can do it. The mechanics had told me it would cost about $1400 to replace the module. With labor what it is, I wonder if it will cost more than that to get a rebuild done. Do you have a guess or do mechanics even do the rebuild?
I'll have to think this one over and try to get my courage built up enough to try the rebuild if that seems to be my best option.
Thank you very much. MareJanee7
- Year and Model: Many Volvos
- Been thanked: 75 times
There are several re-builders that can fix the module. Victor Rocha, Module Masters, etc. and they do it for under $150.00.
http://home.earthlink.net/~vicrocha/
http://www.modulemaster.com/en/index.php
Victor's site has a good tutorial on how to remove the module to ship it to him.
Even without the ABS module at all the brakes will still work fine - you just won't have ABS.
IVIUSTANG
You can also buy a rebuilt module from FCPGroton or IPD etc for around $200. Just get a mechanic to remove the old module and send it in for the core refund, and have them install it as well if you want. $1400 is EXTREME, even the Volvo dealer in Regina would do it for less than $900. The OEM modules are all defective with poor soldering, the only way to permanently fix this is to get it rebuilt, so generally the rebuilds are better than the new parts from Volvo.
- Jesse
- Jesse
polskamafia mjl
- Has thanked: 19 times
- Been thanked: 21 times
If you're feeling ambitious you can also do it yourself for free.
willowdog
- Year and Model: 95 850GLT, 85 360GLS
+1polskamafia mjl wrote:If you're feeling ambitious you can also do it yourself for free.
Pull the module, resolder bad joints and put it back together (and dont forget the sealant). Not a major task (a little harder than the Brake Position Sensor though).
What codes are you getting?
IVIUSTANG
Honestly I attempted to repair my own module and it was a sucky job! So hard to get the module open, then my soldering gun was a piece of krap 15w, so I used a butane torch. This is NOT for the average person in my mind.
- Jesse
- Jesse
