Back-up lights not switching on Topic is solved
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
Post by 940-740 »
When I put my 740 estate (1988) in reverse gear, the back-up lights won't come on. I checked all the bulbs and fuses and they all seemed OK.
All the other tail lights work as they should. Someone told me there should be a switch at the gear stick, but I can't find any.
Interestingly, I have a similar problem with my just bought 940 Turbo (1992), only slightly different. As soon as I go into reverse gear the lights come on and then quickly afterwards they go out again!?
Any ideas??
NotUtopia
Post by NotUtopia »
yeah, i have the same problem, when i put it in reverse, they sometimes come on and if they do they immediately go out. i've wiggled my finger around in the housing unit of the gear shifter and that sometimes helps, but it's probably just a connector.
