240 1986 turn signals suddenly stopped working
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
Jeff1964
Year and Model: 240DL 1986 >268k
Post by Jeff1964 »
Been a while since I have visited here- thanks for this website! :o
Three days ago I realized that the turn lamps were no longer flashing when I wanted to turn. I checked the hazards and they work, so my relay is okay. Could this problem be my turn signal / hi-beam switch? (The fuse is not blown).
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
The turn signals and hazard lights do work through the same relay but from different terminals. Give the relay a good hard flick with your finger to see if something is stuck. I have known the relay to stop working on turn signals but not hazards and vice versa.
Before changing the turn signal switch spray it with a switch cleaner to see if it is just dirty.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Jeff1964
Post by Jeff1964 »
Thanks for the prompt reply Bill-
I tried the switch cleaning but that did not work- so I went to the fuse panel again and took the #13 fuse out. Lo and behold it was a 'hider'- the ends were blown but not the middle! Now they work fine...
No more sticking my left hand out in sub-zero weather to indicate my intention to turn. :lol:
Merry Christmas,
Jeff :D
billofdurham
That was a cheap repair. :)
Having been caught out by a hidden break in a fuse some 45 years ago I now use an ohmmeter on any fuse I am checking to ensure continuity. For those who doubt it, cars of that age did have fuses. Some had as many as four!!!
Thank you for the update.
Bill.
Previously:
