Volvo 850 1994 - TRACS/Winter/Sport/Economy Question. Topic is solved
This topic is in the MVS Volvo Repair Database » XC90 2.5T Timing Belt, Water Pump, Serpentine Belt
socialadvance
Post by socialadvance »
Can someone please explain what the following options are used for?
Tracs
Economy/Sport/Winter
I recently purchased my Volvo & have yet to get my hands on an owners manual.
Thank you! [/img]
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2655 times
Been thanked: 1248 times
Post by matthew1 »
Tracs
Like anti-lock braking, but the other way around... keeps wheels from spinning when you're accellerating. Never worked well for me. Uses the same components as ABS.
Economy/Sport
Economy will shift sooner (lower RPM) at less-than-full throttle. Lower RPM = fewer combustion cycles per second = less fuel used. At full throttle, the car will shift at or near redline. If you floor it allways, it makes no difference what this switch is set to. Sport will let the RPMs grow higher in any given situation.
Winter
Transmission starts from a dead stop in 3rd gear. Less torque = less wheelspin in snow/sand/ice.
Pete
Post by Pete »
Winter mode acctually, starts in 3rd when D is selected, and 2nd when 3rd is selected. in L it holds it in 1st.
