Fire trap, is it really that important to look after?
Ivans
Year and Model: V70 2006
Post by Ivans »
I take my 850 to regular service once or twice a year depending on the milage. And my question is would this fire trap be cleaned every service interval? Is this something that I need to pay attention to for once in a while?
I dont know much about car servicing as I normally just go and pay for it =D I went to volvo speed website and found a DIY article about it. And thought I'll ask here. Thanks.
06 V70
95 850 se
t5rrr
Year and Model: 1994 855
Post by t5rrr »
Firstly, remove the flame trap and toss it into the bin, Volvo omitted them in the later 850/x70s.
Also remove the dipstick after the engine has warmed up and see if there is white smoke puffing out of the tube, that is an indication of a clogged PCV system.
Do a search for "pcv system" and "flame trap", many great discussions about this is all over MVS including this from the database:https://www.matthewsvolvosite.com/2009/0 ... r-pcv-job/
Wagon Brigade >> 94 855 NA | 97 Subaru Impreza OBS | 07 Suzuki SX4
Previous Bricks >> 90 240 GLE 2.0 | 98 S70 T5A 2.0 | 03 XC90 T6 2.9
Ivans
Post by Ivans »
Oh my...yes I noticed a white smoke puffing up the dipstick tube. The problem is I don't know how long this condition has been around. Would this cause problems?
By saying "toss in the bin" does it mean I need to replace the fire trap or just leave it without one?
I will look into this further. What does pcv stand for?
Thanks heaps
06 V70
95 850 se
SidneyAB
Post by SidneyAB »
Ivans wrote:Oh my...yes I noticed a white smoke puffing up the dipstick tube. The problem is I don't know how long this condition has been around. Would this cause problems?
Thanks heaps
I copy this from VADIS:
PCV System description.
polskamafia mjl
Has thanked: 19 times
Been thanked: 21 times
Post by polskamafia mjl »
PCV stands for Positive Crankcase Ventilation. You can throw the flame trap away w/o replacing it. A clogged PCV system can cause several problems. A rear main seal (RMS) leak can be caused by a clogged PCV system. I think performance could suffer from a clogged PCV system too.
patrioty3k
Year and Model: 1995 850 Turbo Wagon
Post by patrioty3k »
:?: So the flame trap is also referred to as the oil trap?And you're saying that a turbo system does not need that?My '95 850 turbo s/w does leak oil,but not excessively,i do smell oil inside car when stopped at light and have couple drops on ground...also @194k,but she's just broken in...thanks :!:
1995 850 Turbo S/Wagon,Alpine head w/Sirius Sat. Radio--"OCTANE" power!
200K $400 Sleeper...nuff said!
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
Turbo models don't have flame trap.
Polskamafia was saying that Volvo quit with putting flame trap to models made from '97 and later.To be more precise....in s,v70 non-turbo models.
'97 850 models still have them but,as i heard at this forum,it's totally safe to pull them out & throw away.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
misha
Post by misha »
Ivans wrote:...my question is would this fire trap be cleaned every service interval? Is this something that I need to pay attention to for once in a while?
It's recommended to inspect & clean flame trap,if necessary,at every oil change.
It can make a lot of problems when it cloggs up,like higher oil consumption,poor performance...it can also blow the oil via oil filler cap,etc.
When flame trap become clogged the engine can't breath properly and,like pcv system is clogged,it can blow some oil seals at the engine.
Volvo stopped putting them from '98 in s,v70 models.You can pull it out and throw it away.As i heard at this board,it's totally safe.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Ivans
Post by Ivans »
I just noticed when I open up the hose that's connecting the airbox and the throttle body that the flame trap is already gone missing... It appears the mechanic where I took the car for service took it out.
06 V70
95 850 se
misha
Post by misha »
It looks like this:
Crankcase Ventilation(PCV).pdf
(77.92 KiB) Downloaded 1454 times
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
