240 1990 Seat heater,rear defrost and hi beam/cruise arm etc
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
rainbowwillow63
Year and Model: 1987 Volvo 240 DL
Has thanked: 1 time
Post by rainbowwillow63 »
Hi All and Happy New Year! I'm having several problems with my baby:
1. My seat heater does not work-the passanger seat does?
2. Rear defrost does not work all the time?
3. problem with high beams-this just started happening. When I try to switch from low to hi beams the headlights go out. They work fine on low beam? Every once in a while it will work but goes out when it wants?
4. The cruise control does not work-it worked once when I got the car but now nothing. I'm wondering if the hi beams and this might mean I need to replace the arm. BTW, turn signals work fine.
Proud owner of
1993 Volvo 240 DL
1990 Volvo 240 DL-laid to rest
1987 Volvo 240 DL-sold
1989 Volvo 240 DL-sold
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
1. Both seat heaters work off the same fuse so it is possible the element has stopped working. Check the connector under the seat in case it has worked loose. You can also check for 12 volts at the connector. Replacing the element is possible but not easy.
2.Intermittent electrical faults can be a pain to find. When the rear defrost doesn't work can you still get 4th gear?
3. Two relays to check. The first is in the passenger compartment, location in the first attachment. The second is the high/low beam relay in the engine compartment, location in the second attachment.
240 relays.pdf
(1.18 MiB) Downloaded 458 times
240 headlight relay.pdf
(48.43 KiB) Downloaded 245 times
The second relay can be badly affected by damp because of its position.
4. There are several things to check before you replace the arm.
Fuse #12 covers both the cruise control and the heated rear window relay. Check the fuse but also check, very carefully, that the fuse contacts are good.
Other things to check can be posted later when you have checked the fuse.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
rainbowwillow63
Has thanked: 1 time
Hi Bill,
Thanks for posting the links for me. I'm really sorry about reposting the same question. I'm having very bad short term memory issues right now due to illness :roll: . If I do that in the future could you please tell me? Thanks
I'm going to check the fuses and the outside relay today. Could you please send the download for the 240 relays? The first one won't download for me but the second did download so I have that. Some work for me and others???
Proud owner of
1993 Volvo 240 DL
billofdurham
As it didn't download as a .pdf file for you, we'll try it as a pretty picture.
240 relays.JPG (136.79 KiB) Viewed 1682 times
Bill.
Previously:
