740 GL , Cold start not working.
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
jamesadam
Year and Model: 1990 740 GL Wagon
Post by jamesadam »
Hi, I am in Sydney ( manly vale ) visiting from FNQ. My Volvo has had a bit of work done , but not by a Volvo guy. So cold start no work, once she is warmed up no problem. i also have no speedo, odometer, dash lights.....Dash lights did work after going over bump, now nothing. I am hoping to get someone decent ( honset ) to fix while I am here this week.Any suggestions?
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
The cold start valve will only operate at temperatures below 5F (-15C) and is controlled by the ECU. Have you checked for any fault codes stored?
Your other problem has all the hallmarks of a bad connection or, a commomn problem on older cars, a faulty electrical portion of the ignition switch. Try jiggling the key in the ignition to see if things start working again.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
