240wagon 1990 not getting fuel when starting
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
myroro
Year and Model: 1990 240 wagon
Post by myroro »
i have to continually keep pumping the peddle and eventually it will start and run fine i can even turn it off and it will start right up but after sitting it goes back to same problem i have replaced the fuel filter thinking that was going to help but it did not :x
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
It does sound as though you are suffering from fuel starvation. Check fuse #4, in-tank fuel pump (8 amps) and #6, main fuel pump (16 amps).
If they are OK check that both fuel pumps are running. To check the in-tank pump remove the filler cap and listen at the filler opening whilst someone switches on the ignition. You should hear a brief whirring sound. The main pump is mounted under the car alongside the filter. Put your hand on the pump and have your assistant switch on the ignition. Youi should feel the pump kick in.
Post back with the results of your checks.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
