I am not currently having any problems, but just want to get the check engine light off if possible. I am getting the following codes:
p0135 - O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1)
p0463 - Fuel Level Sensor Circuit High Input
I am not certain where to find the O2 sensor. Would cleaning the sensor possibly solve the problem or does it just need to be replaced?
I have not found much information about the other code, I really have no clue what it means.
Thanks much
S70 2000 - Help with some error codes
Gatekeeper21
- Year and Model: s70 2000
- Year and Model: Many Volvos
- Been thanked: 75 times
Cleaning an O-2 sensor rarely works and with your code it indicates the heater circuit is open. That could be a dirty connection but likely the heater just burned out. The heater is much like a light bulb only hotter.
Does your fuel gauge work? If so just clear that one and see if it comes back.
o2 code is probably the o2 sensor itself. although the wiring could be the issue its more common to be a fault in the sensor. as for the fuel gauge-change the location of where you buy gas(ie...switch from racetrac to bp or what have you) cheap fuel can cause a build up of corrosion on the fuel level sender unit. also run some mild injector cleaner through the tank. should clean off the sender unit. dont use cheap stuff like stp ect... check with your volvo dealer to see what they approve. i use bg oil products. which is approved and used by most dealers
Gatekeeper21
The fuel gauge is working fine, although the gas light goes off and on when the tank is low (been doing that for a while). I will try running some cleaner through and see if that takes care of it. I have already cleared it once, but it just came right back on.
I'm assuming that even if it is the heater of the o2 sensor, I still need replace the entire unit? What is the purpose of this sensor? I don't notice anything strange about the driving, so it is hard for me to understand paying 200 dollars for a new part if nothing is going to change.
Thanks again
Thanks again
confused_al
- Year and Model: 1996 TLA wagon
FYIGatekeeper21 wrote:I am not certain where to find the O2 sensor.
https://www.matthewsvolvosite.com/forums ... =1&t=24698
96 850 Platinum Wagon
98 MB ML320
06 V70
95 850 GLT(RIP)
98 MB ML320
06 V70
95 850 GLT(RIP)
If the heater is bad the entire sensor must be replaced to make the system happy again. The O2 sensor, combined with the MAF sensor and other sensors, determines the fuel mixture on the car for optimum performance and the lowest emissions. The O2 sensor has a lot of weight in the calculations.I still need replace the entire unit? What is the purpose of this sensor?
The firmware in the ECU has limp home modes built in so as to not strand you on the side of the road when most of the sensors fail but the substitute values (guesses) are far less efficient than a properly working system.
Your mileage will suck but in most cases you can get by with a bad O2 sensor. There are cases where you will run too rich and it will eventually cook the catalytic converter.
Gatekeeper21
I did notice on the way in this morning that my mpg has decreased by 3, so I guess this is something worth doing soon. Wasting money on gas is definitely not worth it, especially if it may end up burning out the cat. Thanks for the link above, I found the part on Amazon for almost half the price I could find it elsewhere.
Gatekeeper21
Just to make sure, this is the o2 sensor before the catalytic converter, right?
Btw, I typically stick with good gas (sunoco, 76, bp, etc) to try to prevent anything like this from happening. I will still run some cleaner through and see if takes care of it. The only stuff I have run through over the last few years is stp, so I will definitely find something a step up.
Gatekeeper21
I just thought of something. A couple weeks ago, a hole formed in my power steering pressure hose. My entire engine bay is currently coated in power steering fluid (looks nice and shiny at least). Is is possible that this caused the sensor to short and cleaning the wiring may fix the issue? Not sure if that is something that could be caused by power steering fluid. Where exactly do I find the o2 sensor and connector? I see a wiring harness in between the engine and fan that I think may be it, but I am not certain. Won't have enough light to look around under the car until this weekend, so I am just trying to figure everything out so I can get it done.
- misha
- Has thanked: 152 times
- Been thanked: 402 times
If you're going to buy new o2 sensor,buy ONLY oem Bosch o2 sensor.These cars don't love generic electronic parts.
So...read the Bosch number from your old o2 sensor and buy a new one with exactly the same Bosch number.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- 1098 Views
Last post by ThreeEleven
- 739 Views
Last post by KMizu93
