Hey Peeps,
Kind of think I really f*** up. I changed my water pump and timing belt. Put everything back together, and checked it twice. I went to give the crankshaft the two hand turns, the shaft turned maybe a half a whole turn than completed stopped. All the belts were tight. I went and pulled the allen wrench fron the tensioner and thought it was time to start the car. Had the battery charged. When I turn the key there was a shutter and it was noticed that the crankshaft was not turning. Is there help for my baby a 1993 850glt b5254s
1993 850glt crankshaft appers to be stuck
dodoforbrains
- Year and Model:
Hey Joe
If it is what you said is this bad news
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
Not necessarily. I wouldn't think the starter itself would have enough power to smash a valve, but the only way to tell is to make sure you've got the crankshaft marks lined up just right, and then try turning with a wrench again before you crank it. Take the belt off again, line up the marks, and then re-tighten it. If you want to be extra cautious, pull all the spark plugs and 'blip' the key.
'98 S70 T5
2016 Chevy Cruze Premier
