LED 3rd brake light
SeattleS80
- Year and Model: 2001 S80 2.9
LED 3rd brake light
2001 S80 -73K: I noticed my 3rd upper brake light (LED strip) is out. Is there a fuse or relay that I can check to see, or do these things burn out? Any advice or knowledge is appreciated. Hopefully this is a quick (and inexpensive) fix.
- billofdurham
- Year and Model: 855, 1995
- Been thanked: 5 times
The only fuse is #3 (15 amps) in the luggage compartment fuse box. However, that covers all the brake lights. Check for 12 volts at the connectors on the high level light. If you have 12 volts then the light is U/S.
Bill.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Previously:
SeattleS80
The other brake lights work just fine, so the LED unit above must be done. I shudder to think how much that is going to cost to replace. Something only a Volvo dealership can attend to, I suppose.
- billofdurham
It certainly looks like a dealer part. You could call Erie Vo-Vo, link at top of the forum.
Bill.
Bill.
Previously:
Previously:
- 788 Views
Last post by NickA
- 614 Views
Last post by MadeInJapan
