A few weeks ago I purchased a 00 S80 T6 with 200,000km. The car was not in running condition due to the tensioner letting go. I started working on it today and would like to first do a compression test before taking the head off.
I checked the timing and according to the tiny mark on the crankshaft pulley(took me forever to see it) I concluded that the cam gears are 90 degrees too far clockwise. My plan is to replace the tensioner and reline up the timing. From there do a compression test.
I will eventually replace the wp/timing belt/idler when I know everything that is wrong with it (bent valves etc..)
Can you tell me if there is any other marks on the crank area other than the tiny raised 4-5mm line on the timing belt crank pulley? I put an arrow on how its located (on the cam pic) so just pretend thats the crank pulley.
