Wet Carpet Topic is solved
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
Lucy
Wet Carpet
Post by Lucy »
Have to park under trees. I think maby drain holes needed cleaning. The only drain hole I could find was under the door and I think it is a drain for the air intake grates in front of the windsheild. The carpet is wet on the right front foot area. Are there any other drain holes . I can't find any info. It's not the heater core .Help!
LaRy
Post by LaRy »
Is it a 240 or 740? It would help a lot to know.
Lucy
Post by Lucy »
LaRy wrote:Is it a 240 or 740? It would help a lot to know.
It is an 88 240DL 4 dr sedan. Thanks!
Guest
Post by Guest »
Thanks, it's an 88 240DL. It is wet only on right front footwell and seems to be wet going up towards the dash about 6-8 inches .
LaRy
Post by LaRy »
One friend to me had the following problem giving wet carpets. He got a crack just above the fastening point of the upper hinge for the door. So he had to put silicone there.
SAILOR1125
Post by SAILOR1125 »
I've had this happen in my '85, generally it backs up into the rear passenger foot well but it has come through in the front as well.
The AC system has a condensate drip tube inside the center console, next to the passenger foot area. As I recall the tube is readily visible when you
take off the panel - it is probably filled up with gunk. Snake it out with a
piece of wire and that should solve the problem.
