Intermittent stalling on 1993 850glt
Randy
Post by Randy »
New Plugs, wires & cap. New battery. New fuel pump relay. New low speed sensor.
A couple of times a week the old 850 (140,000 miles) just stalls. (dealer can not duplicate the problem) It has happened at 50 mph and 5 mph. Seems to happen as I let off the gas pedal, but not sure. Tach comes down slowly when it happens, which makes me think fuel or air related rather than electical. However, I have heard that the fuel pump relay needs a full battery??? Fuel filter?? Fuel pump??(expesive!)
Any suggestions?
randy
Post by randy »
Add on: it starts back up immediatley in neutral or park!
Thom
Post by Thom »
My 93 850 GLT is also experiencing a bit of stalling. It usually happens while the car is sitting at a light or at idle waiting to make a turn. It happens about 1x every month or 2. I have used some injector cleaner and changed the gas filter, but I doubt that's the problem. The tach starts to drop and then dies. I was going to try one of the fixes for the other models, such as cleaning the throttle body. It hasn't happened for awhile, but my suspicion is a sending unit such as the one described in one of the chats on the 960: that one is located on the flywheel. They're so many electronic components on the vehicles today, the Saturday mechanic doesn't have a chance.
Jim
Post by Jim »
Had a number of stalls usually when at a slow speed. After reading a number of times about low voltage to the fuel pump relay, I decided to replace the battery. that same day the car stalled, but hasn't stalled since, which was about 2 months ago. I suspect the battery wasn't fully charged when it was installed. I'm convinced it was the battery.
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2656 times
Been thanked: 1248 times
Post by matthew1 »
Wow. I guess I'm not suprised any longer when I hear that the battery is the cause of strange problems. The battery can be the root of much evil in cars. :evil:
Good that you seem to have the problem taken care of.
