2004 s60 sun roof
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
wes robertson
Year and Model: s60 2004
2004 s60 sun roof
Post by wes robertson »
2004 s60 sun roof stopped working spontaneously.Removed negative cable for a few minutes (as i have read on the forum as a possible quick fix). Unfortunatly this did not resolve the issue. Other than replacing the EUM....any other suggestions would be much appreciated.
Thanks, Wes
vegasjetskier
Year and Model: 2010 Toyota Prius
Been thanked: 6 times
Post by vegasjetskier »
Is your alarm system working properly?
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
wes robertson wrote:2004 s60 sun roof stopped working spontaneously.Removed negative cable for a few minutes (as i have read on the forum as a possible quick fix). Unfortunatly this did not resolve the issue. Other than replacing the EUM....any other suggestions would be much appreciated.
Thanks, Wes
Totally dead?
Try re-initializing the roof by locking and unlocking your car THREE TIMES WITH THE KEY, (not the remote) and post back if it got life again.
wes robertson
vegasjetskier wrote:Is your alarm system working properly?
Alarm system seems to be working, however i'm saying this with the respect that i used the panic button to check it.
wes robertson
Thanks, Wes
Totally dead?
No life after locking and unlocking with key 3 times. I've also checked the fuse and its intact.
wes robertson
Im thinking the UEM has maybe malfunctioned. Saw the trhead on replacing the siren module and may take it on in to have a professional take a look.
thanks for the suggestions and any other suggestion will be much appreciated
Thanks, Wes
