850 Parts swap
This topic is in the MVS Volvo Repair Database » 850 Compatibility 1996 to 1993: dash, steering column, airbags
new2volvo
Year and Model: 850glt/1993
Post by new2volvo »
Hi-can anyone tell me if the dash, steering column, airbags and automatic gear shifter from a 96 850 will interchange with a 93. My 93 needs these replaced and I have found a guy that is parting out his 96 but before I buy them I want to be sure they will work. Thanks alot!
Japedo
Post by Japedo »
I am not familiar with the exact differences of the 93 vs the 94 and up models. I do know there are alot of differences though.... Hopefully someone can answer your question for sure :D
2003 v70 2.5tawd black/black 120miles
2007 nissan altima 2.5 cvt 107miles
2001 xc70 211 miles " collision"/ parts car
1994 850 turbo 315miles 5 speed "stoped fixing it"
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
I looked up part numbers in VADIS and the steering wheel changed at the end of the '93 model year, the air bags changed at the end of the '95 model year, the steering column changed at the end of the '94 model year and there are some badging differences.
I'm not sure how substantial the changes are and they may well work fine but the part numbers are indeed different. If you are getting the stuff cheap enough it might be worth a try.
new2volvo
Post by new2volvo »
Yea I think it may well be-everything together is less than 180.00-including the airbags. Thanks alot I appreciate it and I will let you know how they turn out!!
new2volvo
Post by new2volvo »
I did the change and everything fit perfectly with one exception-the airbag connector is different on the steering wheel bag-other than that it was all good!!!Thanks every one!!!!
cmblackburn
Post by cmblackburn »
O.o so your airbag isn't connected? you might want to look into that!
