cooling system Topic is solved
Usually it is no problem with air trapped in the cooling system. Adjust to maximum heat, so no air can be trapped in the cabin radiator.
My solution is to press the upper radiator hose rapidly with my hands so it is getting compressed. It is rather soft and long, so it is no problem. The system is "breathing", and you can acually see how air is coming out in the resevoir. I use to do first without running the engine while filling the system with coolant + water and continue to do it also with running warm engine. I do it normally 10 times when cold and 10 times when engine is warm. In this way you get all the air out from the cooling system.
