I have replaced the switch, checked all the fuses, locked/unlocked with the key in the door, disconnected the battery for an hour and prayed!
I cannot get the sunroof to close. Can anyone give me some advice on how to get it closed? Its in the vent position.
Thanks
my email address is [email protected]
Jeff
S 80 Sunroof Won't Close
S80 Sunroof Won't Close
vegasjetskier
- Year and Model: 2010 Toyota Prius
- Been thanked: 6 times
Are you getting an "Alarm System Service Required" message?
jeffdowns
- Year and Model: volvo 2000 s 80
No. And this is an intermittant thing too. I bought the car about a week ago. The older gentleman that I bought it from was really meticulous with it. He actually had the switch replaced and that didn't fix it. I had both switches so I replaced the one that was in it this AM but still nothing.
vegasjetskier
You can try locking/unlocking 3 times in a row with the remote to reset the Upper Electronic Module.
jeffdowns
Is the module motor located under the light box near the rear view mirror? I dropped it earlier today to put the other switch in. Saw a small black box but didn't do anything to it.
Also, when I either open/close/lock or unlock the door there is a buzz that lasts about one second coming out of the drivers door. Do you have any idea what that could be?
vegasjetskier
I'm not sure where the motor is. The UEM is in the rearview mirror, I think. If the alarm siren goes out, the sunroof won't work, which is why I asked if you were getting the message. Does your alarm work OK?
jeffdowns
I THINK it does. I have set the alarm off with the remote to see if that worked. The loud horn went off and I turned it off quickly. Is that what you are referring to?
By the way, thanks so much for your help.
vegasjetskier
Yup, that's it. Sounds like it's working OK. The sunroof problem is probably somewhere else.jeffdowns wrote:I THINK it does. I have set the alarm off with the remote to see if that worked. The loud horn went off and I turned it off quickly. Is that what you are referring to?
I vaguely remember someone posting that you can crank the sunroof shut by hand with a wrench. I'd look for a hex on a shaft up by the mechanism to see if you can do that. At least you could keep the rain out.
vegasjetskier
One more thing, is the sunroof ground wire connected securely?
- 1498 Views
Last post by SuperHerman
- 1115 Views
Last post by nthnnxn
- 2174 Views
Last post by quirozson
- 16 Replies
- 13747 Views
Last post by MoVolvos
- 16 Replies
- 3251 Views
Last post by oragex
