Has anyone had these codes on their S80, and know the fix for them?
P0154 02s ckt no activity detected 2/1
P0174 system too lean bank 2 (i figure this one is for the o2 sensor)
Question - Basically which set of 02 sensors is this referring to?
I also have these codes, but it is from my transmission needing to be rebuilt...
P0756 shift sol B ckt perf stuck off
P1181 man. specific dtc (i figure this one is for the trans ?)
P1618 man. specific dtc (i figure this one is for the trans ?)
S80 codes question
S80 codes question
2004 Volvo XC90 AWD - 170,000 miles
2010 Volvo XC60 AWD - 145,000 miles
1996 Volvo 850 Platinum - 201,500 miles - KILLED BY UNINSURED DEER _
vegasjetskier
- Year and Model: 2010 Toyota Prius
- Been thanked: 6 times
If you go here you can plug the codes in for definitions: http://www.equus.com/
I think bank 2 is the passenger's side.
Thanks for that link to the obd codes, and the info on the o2 sensors!
The updates are in red below from the obd code website...
P0154 02s ckt no activity detected Bank 2/Sensor 1
P1181 man. specific dtc - P1181 Volvo Fuel Adaption, Bank 2
P0756 shift solenoid B circuit performance stuck off
P1618 man. specific dtc - P1618 Volvo Fault in Lead Between AW 50-52 and Motronic 4.3 (MIL Requested)
Does this help anyone provide more info?
