Exhaust sealant after converter
- Year and Model: Many Volvos
- Been thanked: 76 times
The problem there is normally the clamps themselves. Beyond that about all you can do is weld it but that sets you up for a turbo back or manifold back replacement the next time something goes wrong. When I replaced my son's exhaust manifold I noticed that the joint had been welded.
Try the new clamps first, they are fairly cheap.
A new clamp was installed with the converter but it still leaks. Apparently, the socket connection at the inlet of the muffler changes shape a bit over the years. The seal is maintained because the ball connection at the exit of the converter changes with it. When a new converter only is installed, however, it doesn't precisely mate with the old muffler inlet. Hopefully, the metal will creep a bit with heat cycles and make a better fit eventually.
JDS60R
- Been thanked: 3 times
Exhaust sealants are popular in Europe for performance/luxury cars. There are many to choose from. Hylomar is a well know name with this product.
http://www.ehylomar.com/Sealants-Adhesi ... t-Sealants
I have also used hi temp Copper from Permatex but this is better with temps at 700f or below .
Retired
I've used Volkswagen exhaust connector/clamps. They are about 5 inches long and have two clamps on the sleeve. Cut the ball off the one end and the socket off the other . Measure the outside diameter with a caliper and check out those connectors, there are about 5 or 6 different sizes. Used one on a Subaru today, worked sweet. Did it to an 850 last week. A bit easier for me though, our Volvo dealership is also a Volkswagen dealer, oh yea, and I work there
Also NAPA has some black exhaust goo/sealer that works fantastically.
- 4963 Views
Last post by MadeInJapan
- 1800 Views
Last post by greg850r
- 1015 Views
Last post by Johnaldo
- 12 Replies
- 6970 Views
Last post by erikv11
- 3205 Views
