turn indicator lights are solid light
My left and right turn lights are starting to not blink. I put the lever in position and the indicator on the dash and the actual light remain solid on until the lever is back to neutral. Is there a switch or module I can replace? (I am getting honked at,
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 94 times
- Been thanked: 146 times
Classic bad blinker unit. It's built into the Hazard light switch. They die...
Good news? Really easy to change.
Pull the radio out ( leave it plugged in if you haven't got your radio code! ),
reach behind the Hazard light switch and it'll pop right out with just a nudge.
Unplug - Replace. Done.
Until then, you can blink "manually". It's a pain, but they won't honk.
Bad News? Well, call these guys for the bad news...
DW Volvo / Parts Dept
(800) 689-0021
Ask for Don or Jamie
You can give it a short, sharp shock and it may come back,
but it won't last. Like I said. They die.
(800) 689-0021
Hi there, just going thru the new posts, happens that I just submitted a fix for your problem.
Hope it works for you.
Here is the link to my post:
https://www.matthewsvolvosite.com/forums ... =1&t=27573
- 5558 Views
Last post by AnyMajorDude
- 744 Views
Last post by paulys problems
- 1578 Views
Last post by davidcschulte
- 792 Views
Last post by mitch944
- 2280 Views
Last post by ndphotonl
