How to find the right catalytic converter? Topic is solved
Guest
Hi. I'm trying to buy a catalytic converter online for my 96 Volvo 850 GLT, but I'm confused about all the configurations. 4-bolt-inlet vs. 2-bolt-inlet vs. spinning-front flange; with vs. without air pump; California vs. non-California. How do I know which one fits mine? Do you have any good online store to recommend? Is it doable without special tools? Thanks a lot.
http://www.all-catalytic-converters.com/ Yes you need to know the number of bolts and if you have an air pump. Remember that the O2 sensors must be moved . If you do use the old sensors put antiseize paste on the threads.
- 4441 Views
Last post by MadeInJapan
- 1711 Views
Last post by greg850r
