removing ac system 1991 244 na
so im taking out my ac system. its an r12 diesel kiki 6yl comp with the larger accumulator. anywho i was wondering if anybody has the bracket to remount the power steering pump from a non ac car. the ac system works i just never use it and dont care enough to convert it to r134a. also looking for a aw3-70 trans same year i can rebuild. [email protected]
Why remove it? You can just let it act as an idler for the P/S belt, its cheaper even if you have to get a good used compressor cluth assy. if it's bad or noisey but that system can be converted ti 134a for under $200.00
...Dick K. from FLA
PS I do have a good AW70 trans fron a 92 but I am A long distance from you
...Dick K. from FLA
- 1524 Views
Last post by snippits75
- 2522 Views
Last post by June
- 3408 Views
Last post by alschnertz
- 2086 Views
Last post by volvolugnut
- 1170 Views
Last post by zimmerdale
