850 Cooling Problems Topic is solved
J McKenzie
I recently replaced the radiator on my 96 850, non turbo, because of a leak in the plastic end cap. A week later the engine overheated again so I replaced the thermostat. 2 weeks later another overheat so I replaced the fan relay. Yesterday another overheat. The problem is intermittant and only occurs in stop and go traffic. Any ideas?
With that many overheats I would look at a head gasket or a cracked head kind of problem. If you are having a problem with either it will pressurize the cooling system and cause it to
95' Volvo 850 GLT, Lots 'o' miles, 118k, Broke in just right.
90' Ford Ranger 4x4, Even more miles, 145k, Seat is broke in just right.
02' Ford F-250 Super Duty 4x4, 85k, Working on the first 100k
J Mckenzie
Thanks for the reply Da' Moose. I don't see any evidence of head or block damage, no oil in the coolant or vice versa, and it runs fine. Prior to replacing the fan relay there was an incident where the fan should have been running but was not, and it started after tapping on the relay. That motivated me to replace the relay. I continue to suspect the fan circuit because it only happens when the car is not moving forward, ie, no air flowing over the radiator. The two suspects are the temp sensor and fan motor. The intermittant nature of the problem makes it tough to nail down. By the way, do you know where the temp sensor is mounted? I haven't been able to track it down.
Thx
Thx
The only one that I know of is right under the gooseneck for the upper rad hose. I have been looking for a port to put a temp gauge in, aftermarket. I will need to look and see if there is one just for the fan. Back in a bit.
Da'Moose
Da'Moose
Well after looking though the Haynes manual and the Mitchell Diagrams I downloaded though Matt
- 1480 Views
Last post by andyj32
- 3493 Views
Last post by RickHaleParker
