Rear caliper removal...urgent
1996 - 2004 S40
1996 - 2004 V40
AlanS
Been thanked: 2 times
Post by AlanS »
I have the car on blocks...2001 S40. The caliper will not come off. Obviously the emergency brake cable is a tad too tight, even at 'release'. I cannot get to the handle (where, on most cars) to back off of the cable. I am assuming there are nuts on the end of the cable. It must be inside the console, but haven't a clue as to how to get in there. There is a plate on the back of the console, but when you take out the ashtray (rear), there are two things that I have never witnessed that seem to hold it in.
Anyways...how do I get some slack on the cable???
JDS60R
Been thanked: 3 times
Post by JDS60R »
Here you go
2001 s40 parking brake adjustment.pdf
(62.77 KiB) Downloaded 406 times
2001 s40 rear console removal.pdf
(34.57 KiB) Downloaded 322 times
Retired
JDS60R
Post by JDS60R »
And a little more
2001 S40 rear brake pad removal.pdf
(158.39 KiB) Downloaded 1272 times
Retired
AlanS
Post by AlanS »
Thanks, but that does not have how to remove the console where the brake is. It assumes that you have already gotten to that point and addresses the section where the shifter is. I need the REAR of the REAR console.
JDS60R
Post by JDS60R »
Ok
But the fact that Volvo labeled their repair procedures incorrectly is 100% your fault.
Good Luck
2001 S40 rear center console 01 model year.pdf
(38.66 KiB) Downloaded 278 times
Retired
AlanS
Post by AlanS »
I can now garuntee you that the PDF is wrong. Firstly, there is an access panel on the back (by the ashtray). This I was able to get off, finally. It will allow me to fool with the cable. BUT...the console is now 1/2 off, there are none of the items mentioned on the diagram. No #3 or #4. The darn thing is stuck and I can't figure out how to unhitch it. Flashlight, mirror, small screwdriver to pry...nothing...
JDS60R
Post by JDS60R »
Sometimes they use 3M stick tape to stop them from rattling. Keep looking or stop . If you can adjust the cable then put it back together when you are done.
Here is the parts picture of what you are dealing with.
2001 S40 parts of center console.pdf
(123.16 KiB) Downloaded 226 times
Retired
AlanS
Post by AlanS »
Got it, thank you!!!! There is a small rectangular access panel at the bottom of the bucket...so hidden / so camouflaged, that I missed it. The fuzzy grey interior had it blend in. Two screws....OUT like butter. Now, the task of cleaning all the crap that my son (24 y.o.) spilled, dropped, etc. in there. I can now loosen the E-brake...but that will be a job for tomorrow...heck, this tired me out!
JDS60R
Post by JDS60R »
Glad to hear
Retired
