mbc not working properly
How to go faster, stop quicker, and turn harder. Chips, exhaust, larger turbos, bigger/slotted/drilled rotors, high performance brake pads, manual boost controllers, performance shocks/struts/springs, airbox mods and more! Also discussion on HID and Xenon lights, aftermarket foglights and other exterior lighting.
raint5
Year and Model: 1996 850 t5
Post by raint5 »
so i installed a mbc today, when i took it out and tried tuning it, i couldnt get more than about 3 psi out of it, i continued to adjust it up more and more, no result, i finally turned it down all the way, and managed to get approx the stock 9psi, any suggestions?
soon to come, mbc; boost, afr and oil press. gauges
raint5
Post by raint5 »
nobody knows anything about this???
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 19 times
Post by jblackburn »
Most often a car can't build boost up because one of the 3 vacuum lines to the turbo is cracked away or missing. Thus, the wastegate will dump out all of the boost as a failsafe.
'98 S70 T5
2016 Chevy Cruze Premier
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2658 times
Been thanked: 1248 times
Post by matthew1 »
Sorry, never added an mbc to my 850 to address specifics, but is your car stage 0?
Also -> Amazon link
JDS60R
Been thanked: 3 times
Post by JDS60R »
Tell us which MBC you are using and how you hooked it up. The Volvos use a three hose system and not a two hose system like most manual boost controlers. You may have hooked it up wrong. Without knowing exactly what you did , and everything that you did , we are unable to diagnose the situation.
Just the fact sir -just the facts
Retired
raint5
Post by raint5 »
ok, now i think about it i didnt hook up the line that goes from the stock boost controller to the maf, how do i need to do this? and is that most likley the problem?
raint5
Post by raint5 »
so it just crossed my mind a couple minutes ago after a little thought, that even if the problem is that the boost line to the maf isnt hooked up, that still doesnt explain why the boost would increase when the controller is turned all the way down, just a thought.
