New Grille
It's amazing what a New Grille, Headlights and Foglights can do.
georgeleedom
- Year and Model: S70 GLT 1999
- Been thanked: 2 times
I just replaced my stock headlights with jewels off an '04 c70. I also added fog lamps. The last part of my face lift was an egg crate grille. Unfortunately, It came without an accommodation for the slash so I had to screw it on, but you really can't see it unless you know it's there.
'99 S70 GLT:
16T turbo, 465cc injectors, iPd tune, iPd coils, Walbro 255LHP fuel pump, Chrysler 4bar regulator, H&R Springs, iPd anti-sway bars, ceramic brakes, strut brace, B&M tranny cooler, Samco hoses, K&N filter, 3"Borla exhaust.
lienmarine
- Year and Model: 1998 V70XC
Damn, that looks CLEAN. I have to get ahold of an eggcrate for my XC. For some reason, the previous owner decided that it would be a good idea to replace the factory eggcrate with a waterfall w/blue emblem....ugh
1996 850 N/A 5 Speed 167k SOLD
1998 V70XC 153k
-Full Stage 0, HD End Links, K&N, IPD HD TCV, Forge DP BOV, shortened wastegate actuator, IPD boost gauge, Mobil 1 oil and bevel gear, 8000k HIDs, PIAA fogs.
1998 V70XC 153k
- Has thanked: 2856 times
- Been thanked: 1332 times
George, that looks fantastic. You updated the car's look 5 years.
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
That looks awesome! I want to do this to mine now
Do the new headlights help your nighttime visibility at all? My low-beams are terrible.
'98 S70 T5
2016 Chevy Cruze Premier
Hoov
- Year and Model: 850 GLT 1996
WOW! SOOO Cool!
I'm usually not interested in appearance "mods"
Most times I prefer the stock look simply because I like vintage cars but THIS is wonderful!
Well done!
Have you got a write up in the works or thinking about putting one together? ... It would be popular ... What inspired you to do this? I mean, are you just into design or simply hated the old look or maybe just "saw" this in your head & then decided to do it?
Awesome mod! Stellar idea. I'd like to hear more of your thoughts about this. The results are Killer!
Hoov
Well done!
Hoov
georgeleedom
All the lighting came from swedishautoparts.com I spoke to Tony and he knocked about 20% off since I bought everything at once. All the lights are genuine Volvo. The fogs came with the grilles, rocker switch, jumpers and relay. The wiring is already there since they were an option for the S70. The instructions were very detailed. I'm a shade tree mechanic at best, but installed everything myself in a couple hours.
The vision at night is unbelievable brighter. It's a much bigger difference than I expected. I've done a lot to make the car go faster and handle better. It's nice to be able to see up the road a bit.
I had seen photos of volvos on the net with similar mods. With a little research I found the headlamps were available on the '04 c70 and are an exact fit. You can't just replaces the lenses though. The ridges on the original lamps direct the light. The reflectors are different for the clear lenses so you have to replace the whole assembly.
The egg crate grill is from IPD. I looked around on eBay, but no one was any cheaper. I've bought parts from IPD before and I trust them.
Thanks for all your comments.
'99 S70 GLT:
- 1743 Views
Last post by MILLSY
- 6756 Views
Last post by ashyu
- 1595 Views
Last post by Sommerfeldt
- 1306 Views
Last post by JRL
- 2020 Views
Last post by clifford06
