To-do lists for your Volvo this Spring?
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2866 times
Been thanked: 1332 times
Post by matthew1 »
Mine: Oh, and antenna replacement. My girlfriend took my 850 through the car wash machine a few weeks ago -- with the radio on -- to surprise me with a clean Volvo. Yea, she surprised me.
Edit: adding the following
  • injector refurbing (removal, soak in Seafoam overnight)
  • replace that one difficult black vacuum tube... goes to the bottom of the turbo
Reason: added more items
Also -> Amazon link
polskamafia mjl
Has thanked: 19 times
Been thanked: 21 times
Post by polskamafia mjl »
Haha, I'm sorry to hear about your antenna.
Here's my list:
Entire front suspension rebuild
Rear shocks
Oil and ATF replacement
T-stat and coolant flush
Replace interior and dash light bulbs
Upper motor mount
PNP switch
and interior cleaning
Can't wait until it's all over and done with. :-D
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 20 times
Post by jblackburn »
Hrm...I guess I'll list these in the order of importance:
-Ignition switch
-Install new front turn signal assy.
-Clean/flush out Intercooler
-Vacuum hoses - I'm slowly losing them one by one, I figure I should just replace them all.
The bad thing is I've just been stealing pieces of hose to fix these from my dad's "parts" BMW, the 35-year old rubber hose is still in far better shape than any of the ones Volvo used.
-New radiator :(
-Lower motor mount
-Door check (again)
-Drivers door lock assembly
-Radio/interior switch/shifter light replacement.
-New shocks all the way around ($$$)
-Alternator & battery (at least before next winter comes around)
Just did within the past 2-3 months:
-ATF flush
-oil change
-New oil cooler & lower trans. cooler lines
-Added new TCV
-Changed dash bulbs
-PCV system
-Rear brakes & rotors
-Seafoam
This is all assuming my car doesn't spring another huge oil leak from who knows where.
I'll try to take pictures and things along the way and add to what other people have already done to make it easier for those of you that have to do these things in the future.
Matt, I did the same thing to my antenna a few years back...I couldn't blame that one on my girlfriend. :oops:
'98 S70 T5
2016 Chevy Cruze Premier
MNCO1
Year and Model: 850 T-5 1997
Post by MNCO1 »
I was busy on my car during the early winter so my list is pretty superficial and smaller.
Oil/ filter using synthetic
Strip and paint the roof trim
Prep and paint both bumpers, dyes do not work!!!!
Clean the fabric ceiling
whoa
Year and Model: 850 Turbo Wagon 1996
Post by whoa »
Yeah, my list has been going down rather than up...knock on wood.
  • Front-end alignment
  • Drain/fill transmission.
  • Replace blower (the squeaks are back a couple of weeks after oiling it)
  • Figure out why the trip computer lamps are out after fixing the odometer
  • Pray for "Forte Seal Conditioner" to work
  • Replace RMS when it doesn't
1996 850 Turbo Wagon
Intelxeonmaster
Year and Model: '96 850 Turbo
Post by Intelxeonmaster »
matthew1 wrote:Mine: Oh, and antenna replacement. My girlfriend took my 850 through the car wash machine a few weeks ago -- with the radio on -- to surprise me with a clean Volvo. Yea, she surprised me.
Now, when you say radio bulbs, I think you should take a better look at this situation. I came to the conclusion that it isn't the bulbs in the radio most of the time, but in fact it's the wiring harness. There are multiple wires for illumination. I discovered this when i swapped out my stock deck (mostly cause it had a short in the volume knob, where only the left side played) with a stock deck from a 97 with a CD player too!!! (yay!) and to mu surprise, the same lower right side of my radio face still didn't illuminate. I know that this radio fully illuminated in its past car (cause my friend wrecked his wagon) and i know it is 100% functional. So before you go through the headache of busting open your deck, check the harness cables.
Volvo Newb
Year and Model: 1998 V70
Post by Volvo Newb »
I bought my v70 at the end of March and got started...probably paid to much for the car.
Things I have done:
Timing belt, Tensors, Cam seals
Serpentine Belt
Right Spring Seat
Fixed the 6 CD changer found the lost cable
Things still needed that I know of
All engine mounts.
ATF Flush
Catalytic converter/ o2 sensors
Drivers side spring seat.
Exhaust hanger
Figure out why my sunroof will open but not close properly.
Figure out how to fix passenger side rear door. (stuck lock?)
Replace cigarette lighter
and trip computer option (is this even possible?)
Figure out why my lock switch will lock everything but not unlock anything.
Clean the carpet again!
c_leforce
Year and Model: 1997 850glt
Post by c_leforce »
vacuum hoses
expansion tank
top motor mount
door check
pads and rotors
start interducing new ATF into the old and hope it doesn't do in the tranny
pcv
oil/filter
fuel filter
cbv
timing kit <--- staying away from doing this myself
This is just the second half of my list finally got the first half done.
lienmarine
Year and Model: 1998 V70XC
Post by lienmarine »
Assuming I don't sell the car before I deploy (still up in the air)-
Re-paint bumpers and trim
Replace "aftermarket" waterfall grill with original XC eggcrate
Get the headlamp wipers working
Re-dye driver's seat
Replace radio bulbs
Figure out which motor mount is bad
Re-align steering wheel
Replace wastegate lines
Replace turbo drain seal
Replace sunroof seal
Tint the tail lights
Driver's side door check
All little things, but i like to tinker. Should keep me busy for the next 50 days before I take off. If only the wife would leave me alone....
1996 850 N/A 5 Speed 167k SOLD
1998 V70XC 153k
-Full Stage 0, HD End Links, K&N, IPD HD TCV, Forge DP BOV, shortened wastegate actuator, IPD boost gauge, Mobil 1 oil and bevel gear, 8000k HIDs, PIAA fogs.
shiloh51933
Year and Model: 04 XC70/'98 V70XC
Has thanked: 28 times
Been thanked: 17 times
Post by shiloh51933 »
My 96' 850 GLT list,
1.front/rear brake pads
2.Tensioner or tensioner pully
3.Timing belt is due(90 something miles)
4.PCV system
5.Oil/filter change
6.Tranny fluid drain n' fill with 1 Lucas tranny treatment
7.Radiator coolant change
8.Spark plugs, cap, rotor, wires
9. Replace taillight lenses
10.Headlight wipers replaced
11.Get skid plate 4 under oil pan
12 New rear tires
13.Gas filler door latch
Yeah I think quite a bit but i just copped this ride a couple of months ago and I want 2 make sure i hit everything
possible n then sum yah know. If any body has sum suggestions on anything else I should do or check, please by
all means share your knowledge cause that's what i'm here 4. She's a beauty and i'm exstatic bout hooking her up
2 stage 0 then doin' sum mods/upgrades. :D :D
If U Wanna Play U Gotta Pay!!
Present Volvo Ownership:
2008 Volvo XC90 V8 Black
Previously Owned Volvo:
1996 Volvo 850 GLT Silver
1998 Volvo V70XC Dark Blue
2000 Volvo V70XC/SE Dark Blue
2004 Volvo XC90 T6 Gold
